Iveco EDC17CP52 513132 DPF off
Results 1 to 13 of 13
    electrones's Avatar
    Feb 2012
    Around C.V
    Default Iveco EDC17CP52 513132 DPF off
    Hi friends
    Can some one help to remove DPF-EGR for iveco daily 3.0 EDC17CP52 513132, i have dtc p0521 and p0524 car is in safe mode, wires and sensor was checked is ok, oil and oil filter is changed
    Thanks in advance
    Press "THANKS" button. just one click, CHEERS
  2. The Following User Says Thank You to electrones For This Useful Post:
    ghassen (14th October, 2022)
  3. #2
    luca22's Avatar
    Dec 2010
    Here is Your file
    100% tested manual solution
    Don't forgot Thanks and Rep button
    More info on priv
    Luca
    PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
    AND REPUTATION BUTTON (starr)
  4. The Following 2 Users Say Thank You to luca22 For This Useful Post:
    electrones (11th October, 2017), ghassen (14th October, 2022)
  5. #3
    Nov 2015
    Lublin/poland
    Quote Originally Posted by electrones View Post
    Hi friends
    Thanks in advance
    first for free
    pass in pm
    dpf off winols manual
  6. The Following User Says Thank You to kostrz3 For This Useful Post:
  7. #4
    electrones's Avatar
    Feb 2012
    Around C.V
    THanks guys iŽll test and report
    Cheers
  8. #5
    electrones's Avatar
    Feb 2012
    Around C.V
  9. #6
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi guys sorry in delay to report but your files doesn't work,
    Safe mode persist when take off dtc car can accelerate without any probs some seconds again safe mode
    Any good solution DPF and EGR please!!
    THanks
  10. #7
    luca22's Avatar
    Dec 2010
    THanks
    My switch solution is 100%
    What DTC give ECU?
  11. The Following User Says Thank You to luca22 For This Useful Post:
    electrones (18th October, 2017)
  12. #8
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by luca22 View Post
    What DTC give ECU?
    Hi lucas persist
    p0521 and p0524
  13. #9
    monitel_service's Avatar
    ROMANIA
    For this type of computer, only switch solution is not enough
  14. #10
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friends
    If someone have good solution for this car but i need good and tested solution, please contact me by mail or skype
    >>>>YOU KNOW THE RULES MATE !!!<<<<
    Thanks in advance
  15. #11
    luca22's Avatar
    Dec 2010
    Hi friends
    Thanks in advance
    Hello
    You have to at the priv that if you have to replace the oil in the engine You must do the oil change(oil service) from the diagnostic interface and DTC from the oil spread out!
    It's so hard ??
    Luca
  16. The Following User Says Thank You to luca22 For This Useful Post:
    electrones (21st October, 2017)
  17. #12
    electrones's Avatar
    Feb 2012
    Around C.V
    Dear luca
    U was and are right, your file work, but in first doesnŽt worked for me, i wrote orig then rewrote your dump and made oil service with Autocon and work car run normally but i have EDC and checkengine is ON and DTC P2452
    If have any way to solve this iŽll appreciate
    THanks
    Cheers
  18. #13
    Jul 2022
    Hello
    You were able to remove dpf.
    If you succeed, you can help me too.
    I deleted it several times with different software, but it didn't work.
