Hi friends
Can some one help to remove DPF-EGR for iveco daily 3.0 EDC17CP52 513132, i have dtc p0521 and p0524 car is in safe mode, wires and sensor was checked is ok, oil and oil filter is changed
Thanks in advance
Hi friends
Thanks in advance
Press "THANKS" button. just one click, CHEERS
ghassen (14th October, 2022)
Here is Your file
100% tested manual solution
Don't forgot Thanks and Rep button
More info on priv
Regards
Luca
PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
AND REPUTATION BUTTON (starr)
electrones (11th October, 2017), ghassen (14th October, 2022)
THanks guys iŽll test and report
Cheers
Hi guys sorry in delay to report but your files doesn't work,
Safe mode persist when take off dtc car can accelerate without any probs some seconds again safe mode
Any good solution DPF and EGR please!!
THanks
electrones (18th October, 2017)
For this type of computer, only switch solution is not enough
Hi friends
If someone have good solution for this car but i need good and tested solution, please contact me by mail or skype
>>>>YOU KNOW THE RULES MATE !!!<<<<
Thanks in advance
electrones (21st October, 2017)
Dear luca
U was and are right, your file work, but in first doesnŽt worked for me, i wrote orig then rewrote your dump and made oil service with Autocon and work car run normally but i have EDC and checkengine is ON and DTC P2452
If have any way to solve this iŽll appreciate
THanks
Cheers
Hello
You were able to remove dpf.
If you succeed, you can help me too.
I deleted it several times with different software, but it didn't work.
