Page 5 of 10 FirstFirst 12345678910 LastLast
Results 61 to 75 of 145
  1. #61
    Jul 2016
    Vilnius
    Hello sir,
    here's your modified EEPROM. Password in PM.
    * MK100
  2. The Following 4 Users Say Thank You to hid3 For This Useful Post:
    altinisik38 (9th April, 2020), antonypaul (19th July, 2023), mtronik (12th January, 2020), nfs (14th April, 2022)
  3. #62
    Newmotors's Avatar
    May 2019
    brazil
    password pleaseeeeeeeeeeeeeee
  4. #63
    Oct 2019
    Hi, on the previous page I posted a file with a solution to the problem with the steering angle sensor on Audi Volkswagen Porsche Toyota and Lexus. On 2 posts below, someone without my will and permission posted the password to this file in plain text.
    What prevents you from using this solution?
  5. #64
    Mar 2020
    Default control sensor error chip 95080
    what do i need for programs and readers to encode chip 95080
  6. #65
    alex2019's Avatar
    Feb 2019
    KUVUKILAND
    Quote Originally Posted by matreshkovod View Post
    A small personal selection of dumps of the steering angle sensor for some fresh VAG, Toyota.
    The technique allows you to programmatically remove the internal error of the SAS sensor after improperly assembling the sensor or scrolling beyond the measurement range.
    I think many will be useful to keep on hand.
    Password for the archive inside the archive
    If you don’t see the password hint (in WinRAR Windows in the right half of the screen there is a comment on the archive), then in the archiver, by which you open the archive, in the menu, find the archive properties, show the archive comment)
    Enter the password with a solid set of characters, without spaces, in capital letters.
    If you are "in the subject)" then a password search will not take a minute, if the search is difficult, then most likely you do not need the information contained in the archive)
    Also, these dumps do not eliminate the need for proper assembly of the sensor, but only remove the error of the internal malfunction of the sensor and allow adaptation.
    Sensors Audi, Porsche with optical disc, Toyota, Lexus with gear ring.
    hi , can u clear mine? its Porche Hybrid 2011 7P5953507 DJ
    Don’t bite off more than you can chew...Don’t bite the hand that feeds you...
  7. #66
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by alex2019 View Post
    https://www.digital-kaos.co.uk/forum...=1#post3841186
  8. The Following User Says Thank You to ricked For This Useful Post:
    Vpaul (3rd April, 2023)
  9. #67
    Jan 2016
    Hi guys, somebody file for unit with procesor D70F3628 ?
  10. #68
    May 2020
    Default 8k0953568Q help
    Hey Guys, have a dump for 8k0953568Q with fault... Basically 2 problems. 1) changing degrees from + to - when turning wheel to the right and vice versa for the right. 2) Locked at 819 degree.
    Appreciate your help with fixing dump!
  11. #69
    salerno
    Hllo Sir , possible psw . thank you
  12. #70
    Aug 2018
    8K0953568 G hello i have the same problem,in my case the eprom 95080 is empty ff ff ..... i need this file.Can you please to give me?
    Best regards Tasos
  13. #71
    Jun 2012
    Hello can you give me the pass thank you 8K0953568G
  14. #72
    Jun 2012
    pouvez-vous me donner le mot de passe 8K0953568G merci.
  15. #73
    wher your bin
  16. #74
    Jun 2012
    Quote Originally Posted by janusz21 View Post
    wher your bin
    Hello, can you help me? I posted my original file thank you.
  17. #75
    tray this bin
  18. The Following User Says Thank You to janusz21 For This Useful Post:
    tekn95 (6th July, 2020)
