Car is for a customer after fixing it he drive it for many days it was all ok . But after he have park it for sale and he leave it for 1 week . Today he tried to start it it was all dead . I have put original dump in cas car back live again. Do you think that it will do the same problem after ?
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
did you check car battery ? it's good?
Sent from my SM-A520F using Tapatalk
Actions speak louder than words
customer thought battery was bad so he tried to jump it but nothing ... he plugged a charger on it for about 1 hour and same story .. so problem wasn't in battery
BMW x3 have no cas, ews 4, cluster, LCM!
when you replace ori dump and fix all issues then not any doubt that it was baterie problem...
car is dead again....if i buy used cas4 and i write back eeprom and flash will car start....
cas4 61.35-9 247 480.9-01
continental 5WK50322KBR
does all number should be the same ?
please i need help
what make inside cas ?
sorry ...what mask?
The mask is 5M48H
Got a similar issue after i manipulated a cas4 1l15y, and it turned out that programmer did not write corret the cas.
In my case car worked okay a week and after that issue apeared.
+thanks if I helped you!
