here you go mate
here you go mate
yukiosan (13th October, 2017)
let me try
hello friend this is new file, pls corect to 50000 km.
y
thank you.
hello carbandit no work have same km.
maybe you edited it to 50000 km thats the problem
i have reset it to 0km try this..
Sharing Is Caring....
eliaselias (18th October, 2017)
you have also need to correct dash mileage
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
xm3n (18th October, 2017)
hello eliaselias, how we can do from dash
remove dash .. open it from back side... remove the small board inside by pulling it out. look for eeprom 95160 and change the mileage in it with vvdi prog or with r270
xm3n (19th October, 2017)
Dash have 080D0WQ 35080 or 35160 depending on the year of the car ...! If you already put the CAS on the car you have to reset it to zero again, do dash and install them back into the car!
What programmer are you using to read the Cas4
"Never confuse the size of your paycheck with the size of your talent"
