Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 69
  1. #16
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Coul it be that something is wrong with starter control and when keys is registered car must be started to confirm and close programming mode?
    A i was able to start car suplied 12 to starter control whey keys was registered. Car started. But when i shut it ofc. Next ignition on is immo light is on agai.
    Cant figiurout wheres problem.
  2. #17
    Duracell2's Avatar
    Apr 2017
    at least the oil is good
    Please hit the rep & thank buttons if this post was helpful!!!!
  3. #18
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by Duracell2 View Post
    Do not do it, if you can not help him leave the post goo away , do you understand Duracell2
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  4. The Following 3 Users Say Thank You to doctore For This Useful Post:
    drugowaz (17th October, 2017), Duracell2 (17th October, 2017), triak88 (18th October, 2017)
  5. #19
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by doctore View Post
    @doctore You are right
    Just wanted to cheer him up. Post is from yesterday, so thought the pressure is out by now.
    But I fully understand. It's a serious problem for him.
    @drugowaz I appologize for the joke. let us know, if you've fixed the problem. good luck
  6. The Following 2 Users Say Thank You to Duracell2 For This Useful Post:
    drugowaz (17th October, 2017), newone (17th October, 2017)
  7. #20
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I understad jokes . No problem.buddy but yeah its stress when car comes by it self and things like this happens. Ownear calls few times a day. Asking its yet . Done. Hows going etc. Tried 3 tools to program and add key by dump. All same. Tomorom will try fvdi. If no luck. Than dont know. Maybe will try looking for "starting" kit.
    was my mistake. I had change to make copy with handy. But NO wanted to try by obd. And now im.dreaming not starting qashqais at night
  8. The Following User Says Thank You to drugowaz For This Useful Post:
  9. #21
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by drugowaz View Post
    Im glad you didn't lost your humor. Hope it will all work out well.
  10. The Following 2 Users Say Thank You to Duracell2 For This Useful Post:
  11. #22
    doctore's Avatar
    Nov 2015
    Colorado Denver
    The tool you use is the most likely your main problem, try with another if you have,
    and return the original dump if you have saved it from the beginning and use original keys
  12. #23
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I used 3 tools. With all same problem.
    I have saved dump. But dump was readed already after problem occured.
    Tomorow will try fvdi.
    Ive tried maxisys. Ck100,pad2. All same. Immo light turns off but no starter.
    Tomorow will return old dump. Ive read it . In dump was 1 key.
  13. #24
    Jun 2016
    EU
    You Must get good tool for this car like nissan consul or g scan 2 or some more expensive tool Avdi or zed full , i was try make key for Nissan Qashqai with SKP900 and FVDi without success and after i get G Scan 2 and success so get good tool for this car .
  14. #25
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I will surely will not buy tool for 3-4k to do this car its not an option.
  15. #26
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I will surely will not buy tool for 3-4k to do this car its not an option. How about consult 3 clone? They are working?
  16. #27
    rob h's Avatar
    May 2011
    Car is still in learning mode.
  17. #28
    Dec 2010
    Nottingham
    You dont need to spend 3k to 4k to do keys on this car , original truecode with NTC2 licence should do these and is reasonably priced , G-scan tab is also capable of doing these and is around £900 , so 2 options that are far cheaper than avdi or zedbull that will also do these .
    cheapest option may be to pay someone with the kit that does do this to come and do it for you
  18. #29
    UK
    Being keyless start model one key should be well away from the car when programming, bring one key at a time in the car. Check if key is locked or cipher ? a lot of tools cant programme this smart keys. Try mvp, use rke function to programme remote side. When asked to switch ignition of and cycle keys, try switching ignition to position 1 and back to 2 with original key only and see if it registers.
    hope you get sorted
  19. #30
    Feb 2017
    suriname
    hi just a question
    i use ez500 xtool never had a problem with adding keys or somthing like that
    when you read the bcm you get 5 numbers
    use calculator then you get 2 number at least i do !
    is it maby possible you use the wrong pin code ?
    give me your bcm number let me see what i get maby its possible you use wrong code
    i have seen that happen with some of my cars
    kind regards mehmet
