Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 69
  1. #46
    drugowaz's Avatar
    Mar 2015
    Lithuania
    starting kit for this car consists of key+bcm+ecu? or anything else?
  2. #47
    Aug 2015
    BEHIND YOU
    i had before the same problem like you but the car was nissan murano 2009..
    when i tried to program a second key...both key stopped working... i was using x100pro.... i have try reprogram with skp900... also it failed ....
    finally i have tried the cheapest tool that i own..it was ck100 .that cost about 80$ ...car started successfully and both key programmed well
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  3. #48
    drugowaz's Avatar
    Mar 2015
    Lithuania
    i have ck100 dont work
  4. #49
    drugowaz's Avatar
    Mar 2015
    Lithuania
    by murano usa it dont go in to prog mode at all. by euro pathfinder it goes in prog,but same no start. i can turn ignition knob eben with key out. it suposed to be like this? car is euro
  5. #50
    Dec 2010
    Nottingham
    surely there must be someone close to you with either G scan , truecode , avdi or advanced diagnostics kit that can try on this for you , has to be cheaper options than alternatives
  6. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    drugowaz (18th October, 2017)
  7. #51
    drugowaz's Avatar
    Mar 2015
    Lithuania
    wrote to dealer ask for programming price.
  8. #52
    Dec 2010
    Nottingham
    with truecode on these , once it states that the pin is accepted , the car is waiting for up to 4 keys to be cycled , so if coding 2 keys once pin is accepted ;
    key 1 on
    key 2 on
    the car is still waiting for next key 3 , so to close keyprogramming session you would turn ignition on again with key 1 , this shuts down programming mode so if not done car would stay in programming mode. if just doing 1 key you would ;
    key 1 on
    then key 1 on again to close programming session .
    this is when using truecode , but may be relevent to you too.
    does your car have a little button next to the twist turn unit ? if yes you must press this whilst turning key off , but again this is with truecode so may not be relevent to your programmer but worth a try
  9. The Following 4 Users Say Thank You to rapidlocksmiths For This Useful Post:
    doctore (18th October, 2017), drugowaz (18th October, 2017), kronk92 (18th October, 2017), Weasel3 (18th October, 2017)
  10. #53
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Car started. It self. It was in lock mode fail atrempts to code. When you wrote about that button i wanted to try as you said . Connecte batery took key and keyless remote. Get in car and hear some kind off bee and saw that lock with needle dont light. Checked central from buton near handrake. It worked now. Earlier not worked. Put key in imo gone bum started. Dont know what happened. Although keyless and buttons from key dont lock dors.
  11. #54
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by drugowaz View Post
    I like to hear this car start
    and now you can check for lamp oil
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  12. The Following User Says Thank You to doctore For This Useful Post:
  13. #55
    Duracell2's Avatar
    Apr 2017
    Am glad he did it.
    Quote Originally Posted by doctore View Post
    LOL
    Oil is good
    Please hit the rep & thank buttons if this post was helpful!!!!
  14. The Following User Says Thank You to Duracell2 For This Useful Post:
  15. #56
    Dec 2010
    Nottingham
    may need reprogramming to get remote working now , you must press button on remote quickly when prompted to do so by programmer .
    the small button next to the twist turn unit on some models , if this is not pressed when switching ignition off , then your not actually switching ignition off , this needs to be pressed if a model with this fitted as you turn ignition off .
  16. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
  17. #57
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Maybe that was problem. I didnt switched it when programming key. But lock.let me take of key from ignition and now if button not pressed it dont let me take out key. As about remote not work im afraid now to do something more program anything on this car
    What do you mean about that quick push buttons? About need to go through whole prog procedure with immo?
  18. #58
    Aug 2015
    BEHIND YOU
    Good news now you can sleep well without nightmare car woke Up from coma
  19. The Following User Says Thank You to eliaselias For This Useful Post:
  20. #59
    Dec 2010
    Nottingham
    on models with the button , on truecode at least you must press this when cycling the ignition off or the ignition stays on , thats on models its fitted to.
    you misunderstand , my comment abount push open button quickly when prompted , is when prompted to code in the remote , when your programmer instructs you to press the remote control button to synch it you must do so quickly
  21. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  22. #60
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Oh . In my tool is function program remote separately. But it wont connect . As first its ask to delete all remotes and than add them. Dont have tool to add keyles for this.
    I think with newer nissans where key is egg shape would be less problems as remote and immo programs same time.
