Who understands, please see what I am correcting.
Hey. I have a problem with cleaning the crash on this block (BHP1-57K30).
If anyone has an opportunity, please help. Or clean or give a dump from
a similar block for analysis and try to decide for yourself.
In the archives, the entire dump and only the last part where the crash itself.
Try and report...
Pass pm...
In case my help has been useful do not forget the magic buttons. ( Thanks and * Reputation ) !!!.
ATTENTION!!!
Attempting to clean files is only to help members. By using these files, you agree to assume the consequences and are aware that all liability for any damages is entirely yours.
Thank you!
megabits.
rozentoo (17th October, 2017)
Good afternoon. Before sewing in a block there were errors of B1193, B1226, B00a0 (a passenger seat was taken off).
After the flashing (a seat was already returned, the bluffs of the pillows had set temporally).
Turned off ignition, in 20 seconds included, again whipped off errors, turned off ignition.
Connected and in a block such errorsB1193, U2100, U0300, B1226, B00a0.
To conduct procedure of primary configuration does not turn out, 2 does not pass a point with weight in 40 kg.
Today inundated the native sewing. All went out except SRS. In the block of error of B1193, B1226.
Guys who have clean dump for this block ??
Вопрос решился. Все работает. Разобрался сам. За участие спасибо Credoline.
hello
Mazda after clear crash need erase DTC using diagnosis Scanner
check this file also
pass PM
