Transponder Type: Blank 8C
You can manually programme the 8C transponder to the vehicle by using the calculated pin code,immobox lucas pin calculate isn number,ecu denso eprom 93c56,ecu mitsubishi eprom 24c01
Mazda premacy 2001 all key lost,need to program?
What is the transponder ID or type?
Does this car use immobilizer? if yes what is the eeprom type and where to locate immo,
I saw in a post where people send transponder chip data with dump from immo or ecu and if both data been modified and written back to immo or ecu car is ready to start,can this be possible that way?
Thank you
Which means the only way to get pin is from ecu? Can I use already used 8c transponder chip from another car to program this car or programming accept only blank chips ?
How to do manually programming?
Thank you
As I'm reaching for the memory it sbb doing it, as you do not want to do on the table, sbb clone
