HI
ned symcro second hand ecu volvo s60 2400cm gasoline year 2003
is ecu denso, inside eprom 93c56
this is the files
cem and ecu secon hand
many idea is apreciate
many thanks in the advance
if need other file as flash and eprom ori file as me
regards
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
morito (16th October, 2017)
h
i open file but wrong password
can you repit me please
Sorry but same problen, I try whit winrar and 7zip but password fault
can send me whiout pass
man thanks for you help
regrds
regrds
hi
many thanks for patience but not can in 3 pc xp. windows7 annd windows10 and winrar 5.31
said this:
G:\new_pcm_95040w.rar: Checksum error in the encrypted file new_pcm_95040w.bin. Corrupt file or wrong password.
dont forget thanks + rep
Here you go doont forget to thanksecu sync.rar
morito (18th October, 2017)
hi
many thanks but not work
whit original ecu the car stars but fault 2 inyectors
whit the second hand sincro ecu the car stars 2 seconds and stop
the second hand ecu is same referency
I tri change flash and eprom but not work
whit original run perfect
regards
i have changed eeprom and flash many times should start no problems. second ecu might be faulty or you changing wrong components
Reality of life :
3:Everyone lies
