Hi friends,
I need virginize ecu from w245 edc16c32 0281015956 .I readed flash bdm. Thank you so much.
Hi friends,
test it .......................
PRESS THANKS + REP
thanks, i test and report
oh notĦĦĦ someone know if is possible swap immo in two ecu edc16c32. Not work my xentry with scn coding and i need swap immo.
here ori file car and used file other car.
same password ...........
PRESS THANKS + REP
vvdi mb tool can do very easy
josma306 (30th May, 2022)
Car start, but i have same problem that with ori file. fault in injector 3, and if i check code injectors in used ecu have codes injectors original ecu. I think that this solution not only copy immo from ori file, also copy data from injectors and i have same problem.
someone know exact location immo code in ecu?
regards
someone can help me? solution selim95 is good for star the car, but also copy corrupt data ori ecu and them also have same problem with used ecu. I test wires, injectors and i am 100% sure that problem is ori software.
I think that is problem, becouse i found other users with same problem. Mosfet injectors OK, wires OK, but ecu have fault in control injector.
http://www.tlemcen-electronic.com/fo...ad.php?t=32392
please help me. thanks
someone have vvdi mb or other tool that found immo code in file dump ecu?
someone know well immo in this ecu?
hi help me tranfes immo mercedes classe a?
