PIN : 52462
CS : 11 DB D3 B4 F1 9D 1E
VIN : WP1ZZZ9PZ9LA47152
Immo ID : VWZ3Z0I1841942
Good job
PIN : 52462
Good job
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
thanks mate, what software did you use for this?.............And thanks for replying so quickly!!!
ANd i tried to learn the key with avdi & it said security access fault after I typed in the pin, anyone got any ideas?
Thank you
I extract info VVDI2
Key 1 ID : 49485CBA
Key 2 ID : 535AE043
Key 3 ID : 3E2801FF
cqae (18th October, 2017)
Pin & CS are not correct.i tried to learn the key with avdi & it said security access fault after I typed in the pin, anyone got any ideas?
I`ll post it tomorrow, I need time to calc.
thanks for your help room, it wouldn't let me log in to keay learning so would be interested to see what you come up with
cqae (22nd October, 2017)
VVDI Prog 4.6.0 update
Kessy 2008-
Read
Then put Dump into VVDI2 and calculate.
Says it only works with VVDI2
cqae (22nd October, 2017), doctore (18th October, 2017), haroutioun (18th October, 2017)
Hello.
the car is European 8 cylinder petrol 4.8, and i think the ecu is simos, and to read this ecu you need special tools to have the immo data. the best way to adapt your key to continental kessy is (TMPro2)
Pin 09073
CS 29 F8 18 0B 83 97 52
Good luck
Hello.
for me the correct pin %100 = 08305
bearheroes (22nd October, 2017), cqae (22nd October, 2017), doctore (22nd October, 2017)
Hello amigokola.
By dump 93c86 continental kessy is so difficult to calculate pin and no tool yet can calculate by dump, but tmpro2 can adapt direct the transponder to kessy by soldering wires, and there is other tool too can adapt direct by connet clip to eeprom 93c86. About vvdi prog i don't try it yet to see the result. but for me the best of continental kessy is tmpro2 and he has so best support.
