yugo45 (17th October, 2017)
Locksmith Hungary (17th October, 2017), yugo45 (17th October, 2017)
If you have VVDI you can try and let us know, I have been asking this for long time, look here on this video , go to 7:40 min, there is a option generate OEM remote:
https://www.youtube.com/watch?v=jHbQL1zYo2Y
It looks like a HB A-JMDB-01 remote.
If yes it's a 315MHZ clonable remote+transponder (ID8E) for chinese market Audi A6
To programming this you will need a hb+ assistant.
The oem remotes have the 8e chip built into the board like id46 keys and the remote programmes at the same time at the immo.
There is no manual remote programming procedure with these.
Sent from my SM-G935F using Tapatalk
Locksmith Hungary (18th October, 2017)
Found a few places selling these for around £170 which is about the same as ordering one in from the dealers minus the wait! They can also be unlocked if you have ELV dump from which they where coded (done a few times when lucky enough to have had option). Remote is 868mhz in EU or program standard key.
I wonder if the Chinese variant pcb has an option for different frequency as does the CAS remotes?
Locksmith Hungary (18th October, 2017), yugo45 (18th October, 2017)
Remote will work only on ori key .now theres new chinese key ship not external. I saw someehere arout 100eur for key. As i remember keydiy made them.
jodge (24th February, 2018)
https://www.facebook.com/audikeyfob/...BXA_1bNMZ9fep8
this is from bulgaria and work , it is have same videos how to program transponder and remote whit avdi and zed-full .
"ß$¤ßłpúőpúßßłŁ$ßßłjáßßłßł$×÷łŁł¤ß=
jodge (24th February, 2018), Nikola1309 (27th February, 2018), yugo45 (25th February, 2018)
trk-audi-04.jpgMake sure that you have the correct mhz.
Europe 868.
And transponder is part of the pcb.
There are after market remote sets.
You plug a Chinese remote receiver, in to the cars wiring.
And the keys are then with a seperate glass transponder inside.
Frequency does matter i think. It atermarket. Not related with cars antenas mhz. And signal goes trhue box itself
