it seems it's more complicated to apply a simple resitor trick
https://m.eet.com/media/1041632/DC_UTH_1533_pg26.gif
2005 Opel/Vauxhall Corsa
Can i disable the tire pressure sensor warnings or the whole sensor like the immo from ecu? Or can i cheat the middle value with a resistor or something? Unfortunately i don't know the sensor at all
The main problem is the spring/autum period in my country when the themperature fluctuation is too high and the sensor going crazy
thx
Sir, are you classified as human? Negative, I am a meat popsicle
M8, just try to code as no pressure tyre sensor installed using opcom.
Regards.
