Results 1 to 4 of 4
    alonedark's Avatar
    Feb 2017
    Default Pinout confort audi a4 b7 8e0 9072279n
    Help me with the pinout of this, i Need pinout of the 32 pins unplug conector .temic module cónfort Audi a4 b7 cabrio 2006 year 8e0 907279 N.
    Thank you un advance
    Nov 2011
    Is this, what you're looking for? Only had the German Pinout, so I translated it with Webtranslation. I think, it's okay for understanding the meaning of the pinouts. If not, ask me.
    Check and compare your cable-colors with the ones below.
    ILM Connector 10 pin
    PIN name: Wire color Target contact / pin Name / destination Comment
    Pin 1 ? ? ? ?
    Pin 2 red / white 2 Pump for SWRA Connector, 1-x, black, A-pillar, left
    Pin 3 green / yellow 1 / 53b Windshield wiper motor Connector, 10-fold, violet, A-pillar, left
    PIN 4 black / white 2 / 53 Windshield wiper motor Connector, 10-fold, violet, A-pillar, left
    PIN 5 black / yellow 36A Backup S236 30A
    PIN 6 ? ? ? ?
    PIN 7 Br Ground connection
    PIN 8 black / green 37A SWRA S237 30A fuse
    PIN 9 red 2 / 75 Ignition switch goes also to the steering column electronics 16a / 12
    Pin10 red 2 / 75
    ILM Plug 23 pin
    Pin 1 black / purple 2 Windscreen washer pump Only sedan. Avant also motor for Rearwiper.Plugconnection, 17-x, black, left A-pillar
    Pin 2 blue / purple 1 Windscreen washer pump Only sedan. Avant also motor for Rearwiper.Plugconnection, 17-x, black, left A-pillar
    Pin 3 ? ? ? ?
    PIN 4 black / green 1 / BR Flashing light lamp rear right Connection(BR),IM wire lane Interior
    PIN 5 blue / red 3 / RF Lamp for reversing light left Only sedan.
    PIN 6 green / blue 5 / blue Flashing light lamp rear left Link (blue) in the wire lane Interior
    PIN 7 green / black 9 / BR Lamp flashing light front right Plug connection, 17-pocket, red, A-pillar, right. Plusconnection (direction indicator, right) in the control panel wiring harness
    PIN 8 blue / red 3 / RF Lamp for reversing light, right
    PIN 9 black / blue 9 / blue Lamp flashing light front left Plug connection, 17-pocket, red, A-pillar, left. Plusconnection (direction indicator, left) in the control panel wiring harness
    Pin10 red / black 2 / 54R Lamp for brake light right Only sedan.
    Pin11 ? ? ? ?
    Pin12 red / white 6 / 54L Lamp for brake light left Only sedan.
    Pin13 ? ? ? ?
    Pin14 black / red 1 / 54 Lamp for 3rd brownake light Only sedan.
    Pin15 grey / white 2 / NSL Lamp for rear fog lamp left Connection of NSL in the control panel wiring harness
    Pin16 white / yellow 1 / 56a Lamp for high beam right Plug connection, 17-pocket, red, A-pillar, right. Connection (56a), in the Dashcables-Harness.
    Pin17 ? ? ? ?
    Pin18 white / black 1 / 56a Lamp for high beam left Plug connection, 17-pocket, red, A-pillar, left
    Pin19 white / blue 1 Lamp for fog lamp right Plug connection, 17-x, black, A-pillar, left-to - connector, 4-speed, black, close front bumper
    Pin20 Br Ground connection in the control panel wiring harness
    Pin21 white / green 1 Lamp for fog lamp left Plug connection, 17-x, black, A-pillar, left-to - connector, 4-speed, black, close front bumper
    Pin22 yellow / white 5 / 56a-5 / 56b Actuator right LWR, low beam right Plug connection, 17-pocket, red, A-pillar, right
    Pin23 yellow / black 2 / 56 b-5 / 56b Actuator left LWR, low beam left
    ILM Plug 32 pin
    Pin 1 green / yellow 6 / 86 Relay for dual-tone-horn (Coil in)
    Pin 2 black / yellow 4 Relief relay for X-Contact (Coil in) Power is interrupted at the start, so that full battery power when starting the engine.
    Pin 3 grey / black 7 / 58L Lamp for light left Connector 17-pocket, red, A column left, contact 1
    PIN 4 grey / black 4 / 58L Lamp for rear lamp left
    PIN 5 grey / red 7 / 58R Lamp for light right Connector 17-pocket, red, A pillar right, contact 1
    PIN 6 grey 1 License plate light Connection in the cable harness interior. Connector, 4-compartment, black, in tailgate
    PIN 7 grey / red 4 / 58R Lamp for tail light right
    PIN 8 yellow / blue 2 Button for warning light
    PIN 9 red / yellow 6 Button for warning light Connection in the wire lane Interior
    Pin10 white / red 2 Brake light switch Connection (brownake pedal switch) in the control panel wiring harness
    Pin11 green / purple 3 / 53e Windshield wiper motor Connector, 10-fold, violet, connector A-pillar left
    Pin12 orange / brown T16a / 8 Control unit for steering column electronics Can bus, low
    Pin13 orange / green T16a / 9 Control unit for steering column electronics Can bus, low
    Pin14 ? 3 Rain sensor Signal contact. Information not 100% confirmed
    Pin15 red / black 4 Brake light switch Connection of 54, in the control panel wiring harness
    Pin16 ? ? ? Not used with me!
    Pin17 yellow / black 2 / 75 Ignition switch
    Pin18 black / blue 1 Automatically dipping rear view mirror Plug connection, 17-times, orange, A-pillar, links
    Pin19 white / purple 11 Interior light front Plug connection, 17-times, orange, A-pillar, links
    Pin20 ? ? any CH / LH Pin4, 8, switch light switch Pin1 Not sure any permanent
    Pin21 black / green + Contact Lamp for side turn signal lamp left
    Pin22 blue / black + Contact Lamp for side turn signal lamp right
    Pin23 ? ? ? Not used with me!
    Pin24 ? 7 CH / LH switch Not sure
    Pin25 grey 14 / 58 Light switch Plusconnection(58) in the control panel wiring harness
    Pin26 tagged Light switches, lighting distance adjuster Connection (56), in the control panel wiring harness
    Pin27 grey / white 9 / NSL Light switch any rear fog lamp
    Pin28 white / green 8 / NL Light switch any fog light
    Pin29 ? ? any light switch 7, 16 Not sure
    Pin30 blue / red 3 Automatically dipping rear view mirror Plug connection, 17-times, orange, A-pillar, links
    Pin31 ? ? ? Not used with me!
    Pin32 purple 3 / TFL Light switch any daytime running lights
  3. The Following User Says Thank You to stefanvr For This Useful Post:
    alonedark (21st October, 2017)
    alonedark's Avatar
    Feb 2017
    Yes, it is ok, but aré you sure is ok. Plup 32 pin : pin 12 can L ,pin 13 can L is no posible . Where is can h
    Nov 2011
    Yes, you're right...
    PIN12: orange/brown is CAN LOW
    PIN13: orange/green is CAN HIGH
