Help me with the pinout of this, i Need pinout of the 32 pins unplug conector .temic module cónfort Audi a4 b7 cabrio 2006 year 8e0 907279 N.
Thank you un advance
Is this, what you're looking for? Only had the German Pinout, so I translated it with Webtranslation. I think, it's okay for understanding the meaning of the pinouts. If not, ask me.
Check and compare your cable-colors with the ones below.
ILM Connector 10 pin PIN name: Wire color Target contact / pin Name / destination Comment Pin 1 ? ? ? ? Pin 2 red / white 2 Pump for SWRA Connector, 1-x, black, A-pillar, left Pin 3 green / yellow 1 / 53b Windshield wiper motor Connector, 10-fold, violet, A-pillar, left PIN 4 black / white 2 / 53 Windshield wiper motor Connector, 10-fold, violet, A-pillar, left PIN 5 black / yellow 36A Backup S236 30A PIN 6 ? ? ? ? PIN 7 Br Ground connection PIN 8 black / green 37A SWRA S237 30A fuse PIN 9 red 2 / 75 Ignition switch goes also to the steering column electronics 16a / 12 Pin10 red 2 / 75
ILM Plug 23 pin PIN name: Wire color Target contact / pin Name / destination Comment Pin 1 black / purple 2 Windscreen washer pump Only sedan. Avant also motor for Rearwiper.Plugconnection, 17-x, black, left A-pillar Pin 2 blue / purple 1 Windscreen washer pump Only sedan. Avant also motor for Rearwiper.Plugconnection, 17-x, black, left A-pillar Pin 3 ? ? ? ? PIN 4 black / green 1 / BR Flashing light lamp rear right Connection(BR),IM wire lane Interior PIN 5 blue / red 3 / RF Lamp for reversing light left Only sedan. PIN 6 green / blue 5 / blue Flashing light lamp rear left Link (blue) in the wire lane Interior PIN 7 green / black 9 / BR Lamp flashing light front right Plug connection, 17-pocket, red, A-pillar, right. Plusconnection (direction indicator, right) in the control panel wiring harness PIN 8 blue / red 3 / RF Lamp for reversing light, right PIN 9 black / blue 9 / blue Lamp flashing light front left Plug connection, 17-pocket, red, A-pillar, left. Plusconnection (direction indicator, left) in the control panel wiring harness Pin10 red / black 2 / 54R Lamp for brake light right Only sedan. Pin11 ? ? ? ? Pin12 red / white 6 / 54L Lamp for brake light left Only sedan. Pin13 ? ? ? ? Pin14 black / red 1 / 54 Lamp for 3rd brownake light Only sedan. Pin15 grey / white 2 / NSL Lamp for rear fog lamp left Connection of NSL in the control panel wiring harness Pin16 white / yellow 1 / 56a Lamp for high beam right Plug connection, 17-pocket, red, A-pillar, right. Connection (56a), in the Dashcables-Harness. Pin17 ? ? ? ? Pin18 white / black 1 / 56a Lamp for high beam left Plug connection, 17-pocket, red, A-pillar, left Pin19 white / blue 1 Lamp for fog lamp right Plug connection, 17-x, black, A-pillar, left-to - connector, 4-speed, black, close front bumper Pin20 Br Ground connection in the control panel wiring harness Pin21 white / green 1 Lamp for fog lamp left Plug connection, 17-x, black, A-pillar, left-to - connector, 4-speed, black, close front bumper Pin22 yellow / white 5 / 56a-5 / 56b Actuator right LWR, low beam right Plug connection, 17-pocket, red, A-pillar, right Pin23 yellow / black 2 / 56 b-5 / 56b Actuator left LWR, low beam left
ILM Plug 32 pin PIN name: Wire color Target contact / pin Name / destination Comment Pin 1 green / yellow 6 / 86 Relay for dual-tone-horn (Coil in) Pin 2 black / yellow 4 Relief relay for X-Contact (Coil in) Power is interrupted at the start, so that full battery power when starting the engine. Pin 3 grey / black 7 / 58L Lamp for light left Connector 17-pocket, red, A column left, contact 1 PIN 4 grey / black 4 / 58L Lamp for rear lamp left PIN 5 grey / red 7 / 58R Lamp for light right Connector 17-pocket, red, A pillar right, contact 1 PIN 6 grey 1 License plate light Connection in the cable harness interior. Connector, 4-compartment, black, in tailgate PIN 7 grey / red 4 / 58R Lamp for tail light right PIN 8 yellow / blue 2 Button for warning light PIN 9 red / yellow 6 Button for warning light Connection in the wire lane Interior Pin10 white / red 2 Brake light switch Connection (brownake pedal switch) in the control panel wiring harness Pin11 green / purple 3 / 53e Windshield wiper motor Connector, 10-fold, violet, connector A-pillar left Pin12 orange / brown T16a / 8 Control unit for steering column electronics Can bus, low Pin13 orange / green T16a / 9 Control unit for steering column electronics Can bus, low Pin14 ? 3 Rain sensor Signal contact. Information not 100% confirmed Pin15 red / black 4 Brake light switch Connection of 54, in the control panel wiring harness Pin16 ? ? ? Not used with me! Pin17 yellow / black 2 / 75 Ignition switch Pin18 black / blue 1 Automatically dipping rear view mirror Plug connection, 17-times, orange, A-pillar, links Pin19 white / purple 11 Interior light front Plug connection, 17-times, orange, A-pillar, links Pin20 ? ? any CH / LH Pin4, 8, switch light switch Pin1 Not sure any permanent Pin21 black / green + Contact Lamp for side turn signal lamp left Pin22 blue / black + Contact Lamp for side turn signal lamp right Pin23 ? ? ? Not used with me! Pin24 ? 7 CH / LH switch Not sure Pin25 grey 14 / 58 Light switch Plusconnection(58) in the control panel wiring harness Pin26 tagged Light switches, lighting distance adjuster Connection (56), in the control panel wiring harness Pin27 grey / white 9 / NSL Light switch any rear fog lamp Pin28 white / green 8 / NL Light switch any fog light Pin29 ? ? any light switch 7, 16 Not sure Pin30 blue / red 3 Automatically dipping rear view mirror Plug connection, 17-times, orange, A-pillar, links Pin31 ? ? ? Not used with me! Pin32 purple 3 / TFL Light switch any daytime running lights
alonedark (21st October, 2017)
Yes, it is ok, but aré you sure is ok. Plup 32 pin : pin 12 can L ,pin 13 can L is no posible . Where is can h
Yes, you're right...
PIN12: orange/brown is CAN LOW
PIN13: orange/green is CAN HIGH
