Results 1 to 9 of 9
    Member rambobo's Avatar
    Dec 2016
    Romania
    Default Tools need to make your job
    Hello ppl, can you tell me what tools you use the most ? I have a carprog, vcds, inpa, kkl 409 and that's it.
    I need china tool that can read ecu via obd, What about MPPS ? did you used it ? it must be modified like carporg ? Thanks and have a nice day !
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Hi, depends what you need the tools for! And also depends what cars you want to check, program, etc.. and that sometimes china clone will mess you a cluster, or a Ecu. It hapend even with original tools!
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
    Dec 2016
    Romania
    i usualy do immo off on 29f200 flash, what about willem ? do i need adaptor for it ?
    Is that a burned eeprom ?!
    electronistul21's Avatar
    Nov 2011
    galati,romania
    yes ,need adapter .in programer you have one DIP32 socket ,and flash have PSOP44 socket.buy Minipro,ist cheap and more reliable.
    Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
  5. The Following User Says Thank You to electronistul21 For This Useful Post:
    rambobo (19th October, 2017)
  6. #5
    Dec 2016
    Romania
    thanks for reply, this week i ll order the toy.
    What about carprog a1 china ? I've opened it and changed resistance position using some pictures from forum but it still doesn't work... ? Do i need to replace MCP 2515?
  7. #6
    Dec 2016
    Romania
  8. #7
    Nov 2011
    galati,romania
    change position resistence and capacitors and try using.if not good,change and MPC515.I see 4 diferent PCB for A1 in to china clona.In this case ist 4 method for rework ,not only one.Maybe need change and tantalum capacitors,transceiver CAN,etc.
  9. The Following User Says Thank You to electronistul21 For This Useful Post:
    rambobo (20th October, 2017)
  10. #8
    Dec 2016
    Romania
    What about this two items ? can i use em to reprogram 29f200?
    https://www.ebay.com/itm/TSOP32-40-4...AAAOSwPcVVmk0M
    https://www.ebay.com/itm/USB-TL866CS...YAAOSw23NZm58u
    Thanks!
  11. #9
    Nov 2011
    galati,romania
    yes ,ist good.in first link you have adapters for TL866 programers.
