Results 1 to 11 of 11
    levisdj's Avatar
    EcuLand
    Default Astra G 1.7 Diesel
    Hello everyone, I got this Opel Astra in today, not starting... I tried to diagnose ECU, but it doesn't communicate...checked the fuses all ok, DTC's stored in immobiliser are : B3040 and B3059 Communication malfunction on W line and No engine request received ... and on ignition the engine check light doesn't turn on neither the car with the key in the middle the car turns but it doesn't start... any ideas ?
    doctore's Avatar
    Nov 2015
    Colorado Denver
    maybe bad earth wire to the ecu and all on chassis and check big fuses
    use opcom and tr reset ecu and immob with pin
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    levisdj's Avatar
    EcuLand
    Thanks for your answer, I did check the fuses, I gave secondary ground to ecu housing, nothing... and opcom does not connect to ecu, as if it was unpluged... I did mention that engine check and car with key does not light on ignition
    Oct 2015
    find ecu pinout and try diagnose at dask. if no communication than your ecu died.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  5. The Following User Says Thank You to rokibar For This Useful Post:
    levisdj (19th October, 2017)
    levisdj's Avatar
    EcuLand
    I found something in the FGTech documents, can someone confirm it's correct ?
    Mar 2012
    Serbia
    Connect two braon/white wire on immobiliser jack and try to diagnose engine ecu
    Shmortz's Avatar
    in the middle of nowhere
    open ECU and see is there diesel in it, you can try to clean ECU and repair it, I have repaired many of this but it is very hard work, or you can just find other used ECU and sync immo, or get it with immobox and transponders from same car...
    levisdj's Avatar
    EcuLand
    Can you exaplin clearly what wires to bridge at the immobox ?
  10. #9
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    This ecu fill with diesel .100% ....i will post photos
  11. #10
    cubica1's Avatar
    Feb 2012
    Serbia
    correct..diesel is inside of ecu..unfortunately, very possible eeprom content is damaged now,
    rgds,
    cuby
  12. #11
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by levisdj View Post
    Where are u located mate, i can send you Some spare.
    Wbr Adam
