Results 1 to 15 of 22
    Jul 2016
    Default BMW 2009 CAS3+ Synch DME-CAS
    Hi Dear
    I have BMW 2009 CAS3+ the battery was dead and the keys lost, I made key with VVDI2 and the key working very good, but the car not start becuse of need sync better the DME and CAS , I try with VVDI2 but give me "Synchronization NOT Possible" the CAS and DME the original one for the car.
    I am try to read the CAS Code-DEM gives me (1A6D) I don't know what is that?
    Could you please tell me how can I do the sync
    doctore's Avatar
    Nov 2015
    Colorado Denver
    cas3+ its crypto have long isn not short
    all key lost situation need isn long from ecu
    you have problem with that now
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    Jul 2016
    How can I fix this problem as you say with ISN, get ISN from ECU or What ???
    Quote Originally Posted by doctore View Post
    i think
    doctore's Avatar
    Nov 2015
    Colorado Denver
    must have isn from ecu or dump
    follow the instructions when making the key, carefully read not hurrying a lot
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Post cas dump i thinki can help you with long isn
    Apr 2016
    uk
    Quote Originally Posted by mlwila View Post
    Hi Dear
    You need to read ecu and find isn.
    Then change the isn in cas.
    Inviato dal mio HTC One utilizzando Tapatalk
    Jul 2016
    This is the dump
    Jul 2016
    I am using that video to read the ISN and I got the ISN from dump, but now what can I do write new key or what write it on the old key that I made before when the car was lost all keys
    Quote Originally Posted by drugowaz View Post
    drugowaz's Avatar
    Mar 2015
    Lithuania
    I had e92 sync by obd not possible on ecus after 2006 or 7. Msd80 85 ecu is petrol. It must be mached not by obd
    Jul 2016
    so how can we sync it
    Oct 2017
    BMW
    made key bad. u have to read isn from engine ecu and make key with vvdi2 using isn from dde\dme
    Jul 2016
    I got the ISN from dump I post before
    So I add it by tango but I didn't add the Key yet is it right way to make key
  13. #13
    doctore's Avatar
    Nov 2015
    Colorado Denver
    you have isn long 32 numbers
    you cannot doo nothing with 1A6D its short
  14. #14
    Jul 2016
    Yes I got the 32 numbers from the dump that I have from CAS it long 32 numbers
  15. #15
    doctore's Avatar
    Nov 2015
    Colorado Denver
    must have isn from ecu or post dump someone will give you
    no other way
    here is support for your tools
    http://www.digital-kaos.co.uk/forums...rrived/page198
