ive Picked the lock but the decode is the bit I'm stuck on like how would i know which side to use will i feel a spring or something. and theres 4 lifter which one should i decode. And should i decode just A or A&B together
do i use the outer lifter to decode or inner
Decode same way as you picked, push wafer passed the springy feel till it stops dead , then take a read
asc7016 (26th October, 2017)
thanks for you help. Im still struggling i decoded the lock and got the code 633367. Cut the key still not working. When im using the lishi i apply tension clockwise. Do you think im doing that wrong. Also shall i use the door barrel or the inside ignition
Please hit the rep & thank buttons if this post was helpful!!!!
