Results 1 to 7 of 7
    Dec 2013
    GB
    Default Please help for BMW F07 coding Key
    I need your help for BMW F07.
    Had to renew the CAS D-Flash. With Ista-p Programmed and coded.
    now everything OK but now the keys no longer work.
    My question.
    Can I insert the key ID in D-Flash?
    Or is there another possibility, (E-Sys) except unlock key or newer.
    See D-Flash and Key files in Zip
    Oct 2017
    BMW
    What tool did u read key ?
    Dec 2013
    GB
    With VVDI 2
    Oct 2017
    BMW
    try renew with vvdi prog and make key again . your cas ews4 not encrypted
    Dec 2013
    GB
    What do you mean exactly ?
    Cas rewrite?
    Oct 2017
    BMW
    i think my 4th post was written clearly . what dont u understand ?
    Dec 2013
    GB
    must the Cas encrypt after?
    and how should I make a new key?
    With VVDI2 says the key is already being used in other car
