    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default vectra c 2004 NO SPEED on dash
    hi,please advice where could be problem?
    owner bought car with this problem. no speed and no km change when driving.
    scanned car,no errors in abs, ecu, cim ,cluster.
    in abs all data good i see all wheels turning.
    in ecu and dash when drive only 0 kmh.
    when do test on dash speed needle increses,for to be sure i put other dash to check. same.
    maybe esp module?
    TRW EBC430EV ESP
    cheero's Avatar
    Czech Republic
    solder connect to dash of pcb
    ++++ GOOD WORK ? + ++++
    FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
    Shmortz's Avatar
    in the middle of nowhere
    soldering will not help, vehicle speed goes trough CAN, I think you have to check all ECU's configurations, look first in ABS module, maybe configured that there is no ECU and/or IPC...
  4. The Following User Says Thank You to Shmortz For This Useful Post:
    drugowaz (19th October, 2017)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    its not solder problem. i tell you i tried other dash too.
    what configurations too look for?
    drugowaz's Avatar
    Mar 2015
    Lithuania
    upadate,you where right about configuarion. it was set to not preset vehicle dynamic system ih high speed can bus it went throuh many garages nobody found reason.
    now speed works.thank guys.
    Shmortz's Avatar
    I am happy to help you, I dealing with many opel cars everyday...
  8. The Following User Says Thank You to Shmortz For This Useful Post:
