Any help ?......
Hello, original dashboard from mb sprinter ~2010 year dead, we try to make 0km and code with star c4, but can't because don't have permission for SCN codding offline. So need help to transfer SSID manualy. EZS dump, old dash eeprom and new dash eeprom attached. SSID A8 AC AD 6F . Thank you.
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
Any help ?......
up.............................
any help..........................?
what is the problem?
first post dont say what is the problem.
do you need the mileage change as original?
do you need to marry the ezs to the dash?
is the dash with other sw then the original?
ect, ect.
In EZS are SSID A8 AC AD 6F need put same SSID in a dash, but can't find, looks like are crypted?
Solved! Very easy!
hello to all
i need help for instrument cluster clk 320 w209
need to replace it
the old one is dead
eeprom unreadable....
i ll try to put mileage to 0
may i know to transfer ssid to the cluster dump?
best regards
Hi.
Can you say how you did?
Regards.Giovani.
How did u find the ssid in cluster what address? i cant find it anywhere!
Good Morning
what is the procedure to change the ssid?
[QUOTE = Saulius Saulius; 3127099] Resolvido! Muito fácil! [/CITAR]
how to solve?
