Flash bsi JC C4 Picasso
Results 1 to 15 of 17
    Dec 2015
    Default Flash bsi JC C4 Picasso
    Here is my concern I recovered a C4 picasso of 2011, nothing more contact after trying to do a reading Pin with an FVDI (learning an additional key)
    So I read the flash with a smok, flash that was blank (1024KO 0000000).
    So after that I recovered on rocket dump a flash that corresponds exactly to the boot of the bsi.
    after injection of the flash in the bsi the car starts but more electric window, more fuel level and the flagship lava that stays on constantly and several engine defects
    I also try to telecode but without success
    attached ref. of the bsi and flash inject
    96 668 956 80 02
    BSI04EV K04-00 280811
    BOOT 2097777-1
    Hard 212458701
    C4 Picasso HDI Exclusive 2011
    doctore's Avatar
    Nov 2015
    Colorado Denver
    post softwer signature
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    nono93 (20th October, 2017)
    Dec 2015
    how and where do I retrieve this ??
    doctore's Avatar
    Nov 2015
    Colorado Denver
    read bsi error you will see softwer signature or folder in fvdi have backup for your file and will see number like this Documents\ABRITES software for ID 1715C7\PSA
  6. The Following User Says Thank You to doctore For This Useful Post:
    Dec 2015
    BSI Siemens,Valeo,JC, JC2015
    Licence Accepted
    Init Ok
    Learned Keys: 18
    Can not read inspection details
    Unknow statsus of History
    Manufacture JONSON CONTROL
    PSA Boot SW : 96668956
    verx1 : 0502
    PSA SW : 96640587
    Plesa wait 20sec and try again
    VIN: ° þ
    KM= 30198991
    Sec Acces I Ok
    Typ Crypto
    Read Ok
  8. #6
    doctore's Avatar
    Nov 2015
    Colorado Denver
    faind softwer signature
    look carefully in first window
  9. The Following User Says Thank You to doctore For This Useful Post:
  10. #7
    Dec 2015
    signature softwe
  11. #8
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by nono93 View Post
    signature softwe
    tr this write with fvdi on bench or with external power on car post result
  12. The Following User Says Thank You to doctore For This Useful Post:
  13. #9
    Dec 2015
    thank you I install but still the same problem
  14. #10
    doctore's Avatar
    Nov 2015
    Colorado Denver
    you have ignition on, car start or not.
    here you goo another
    same p
  15. #11
    Dec 2015
    THANKS
    I dont know what s the problem maybe bsi is dead because i have same problems
  16. #12
    Dec 2015
    the car started but no options
  17. #13
    doctore's Avatar
    Nov 2015
    Colorado Denver
    tr second flash
  18. The Following User Says Thank You to doctore For This Useful Post:
    nono93 (26th October, 2017)
  19. #14
    Dec 2015
    No, she still does not work
    so with your last flash I have more the electric window gearbox deconne and several other flaws
  20. #15
    Dec 2015
    Hello, some would have other flash model the car starts but I have more electric window ect ...
