Results 1 to 8 of 8
    omglol's Avatar
    Jan 2009
    Europe
    Default Corsa C dash swap without car
    Hi!
    Is it possible to swap Corsa C dash "remotely", out of the car? What I mean is ... can I read pin from old dash with OPCOM on bench, then connect new dash on bench, read pin, perform reset and program new pin? Then give dash to the customer plug & play style?
    Nov 2011
    Macedonia
    Quote Originally Posted by omglol View Post
    Hi!
    read eeprom from old dash and write to new dash.......opcom read full eeprom.....or use upa to clone NEC mcu eeprom
    Baze007
  3. The Following User Says Thank You to baze007 For This Useful Post:
    omglol (20th October, 2017)
    omglol's Avatar
    Jan 2009
    Europe
    I see. Can I do that on bench? Do you maybe have pinout? Thanks.
    Nov 2011
    Macedonia
    i have only power up but dont know k-line
    second photo is from D.K
    Baze007
  6. The Following 2 Users Say Thank You to baze007 For This Useful Post:
    damih (24th June, 2019), omglol (20th October, 2017)
    omglol's Avatar
    Jan 2009
    Europe
    This one should be correct, connector looks like the one I have.
  8. The Following User Says Thank You to omglol For This Useful Post:
    baze007 (20th October, 2017)
  9. #6
    Nov 2011
    Macedonia
    its ok......hold trip button when read/write eeprom from dash
    Baze007
  10. The Following User Says Thank You to baze007 For This Useful Post:
  11. #7
    omglol's Avatar
    Jan 2009
    Europe
    I tried cloning with op-com, but won't work. I can read EEPROM, I can change mileage, I can reset IPC ... but I cannot program EEPROM ... nothing happens. :/ Also, I cannot program IPC (programming failed). I tried pushing trip button, nothing. What could be wrong? Only mileage seems to write OK.
  12. #8
    Mar 2016
    I`m trying to connect to corsa c Dash on bench to read pine code by op-come I connected the dash as on the photo but I can`t connect to it, could someone help
    PIN 3,10 +12V
    PIN 5 GND
    PIN 12 K-LINE
