Results 1 to 4 of 4
    Feb 2016
    Nis, Serbia
    Default Citroen C4 1.6 HDI P1613 problem
    Hello guys, I have problem since i read and write by obd galleto , folowed procedure to wait 6 mins etc . But still have problem with codes, and problem is strange :shake:
    When I entered codes from the injectors codes are acepted and car works fine. After i lock car and wait 10 mins and try to drive again I get P1613 and service light and limp mode. When I shut down car and start it again immediately car doesnt have problems or service light and works fine.
    Also when i check every time codes are there , same one that i have entered .
    Anyone with same problem maybe that can help ?!?
    Feb 2016
    Nis, Serbia
    Anyone with any idea, suggestion what to try ?
    Dunker's Avatar
    Yorkshire
    Put original dump back in ecu and recode injectors and check rest of config. Why did u read and write to ecu. If to delete fap or whatever it does cause the problem u have if the mod is not 100% correct.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Feb 2016
    Nis, Serbia
    Thanks everyone for helping , problem is solved with full configuration with lexia !
