Results 1 to 2 of 2
    Nov 2015
    Default Kia Cerato crashed key
    Hi guys,
    I have a quick question. Today I tried to launch my Kia Cerato and due to low battery voltage problably the key was probably crashed in the ECU because the immobiliser icon popped up. Could anyone instruct me what interface should I use to reprogram the key, and if any PIN code is needed to access the ECU programming mode (Of course as cheap as possible ). Cheers and thanks in advance,
    sickz0r
    Apr 2016
    holland
    put your vin nr somebode ore i will tell you pincode you can easely program key
