Page 1 of 3 123 LastLast
Results 1 to 15 of 41
    Feb 2012
    Default Fiat Punto Grande remote
    Does anybody know how can add new remote from e-bay for Fiat Grande Punto 1.4 8V 2006 year.
    szengen's Avatar
    Jan 2017
    You must have ad100pro, or tmpro2
    Dec 2010
    Nottingham
    or abrites , or zedfull even
    Feb 2012
    Uh, I havent any of this tools, I have SKP900, zedbull clone, multiecuscan original, willem programator, carprog clone..., but nothing so expensive. In the next one or two month I plan to buy a tango original.
    szengen's Avatar
    Jan 2017
    tango will not do, transponder yes, not remote control
    Dec 2010
    Nottingham
    a cheaper alternative when you have a machine capable of precoding a remote from dump . is truecode with the fiat licences , but tool capable of precoding remote from dump is needed to precode the key from dump read with truecode by obd , if you dont have any of the kits mentioned in the thread then options are limited to either passing job to someone with kit who can precode it , or order dealer key if you have a unit that can program it.
    Oct 2017
    Since my questions are similar I'll add on here instead of starting a new thread. I recently acquired a 2014 Fiat 500e. I believe I have a similar remote/key problem. My understanding is that one wants to add remote keys like this:
    That the remote must be precoded. However, from reading above that a transponder only key such as:
    is not in fact precoded. So does that mean that if I have a working remote key, that I can use a tool like a Zed Bull mini to configure a couple of transponder only keys?
    Next question: If can accomplish the above, does then losing the remote key cause a "last key lost" situation? Or is the car usable with transponder only keys?
    Final question: What is the cheapest option for adding a second remote key? Again from the above it seems like all the options are expensive.
    Any help would be greatly appreciated.
    ga2500ev
    Feb 2012
    Quote Originally Posted by szengen View Post
    I think, Tango, for other car, because it seems, to me, that it is good tool for the money it costs, or you have better suggestion
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    a similar questions and from me...
    I have a simple key for Fiat g.p (no remote) can i programming new key with remote? and how?
    Aug 2015
    Quote Originally Posted by ga2500ev View Post
    ga2500ev
    You are wrong with most of your questions... Also i am 100% sure cheapest thing would be going to your local locksmith and get the key programmed to car.
    Aug 2015
    Quote Originally Posted by Panathaole View Post
    what tools do you have?
    lidons's Avatar
    Feb 2011
    you can upload your Dumps?
    excuse my English, is the best.
  13. #13
    Dec 2010
    Nottingham
    currently the only tools that have good coverage on adding a remote control to these via obd is , Abrites , Zedfull , AD100 pro , MVP pro and truecode with the aid of a good dump tool like tmpro .
    some other tools may be able to code a dealer precoded key , truecode can , if the keys sourced and precoded from the dealer then true code can code this in via obd without a dump tool .
    there isnt currently a cheap tool to precode and code these by obd , nor is there many dump tools that will prepare the remote either .
    as has been said , if the tools that can do this are too dear , then sub it out to a locksmith with the kit to do it .
    if only wanting to make clone standard non remote keys , then most cloners that can clone id46 can do this .
  14. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    ga2500ev (22nd October, 2017), szengen (22nd October, 2017)
  15. #14
    castin's Avatar
    Oct 2015
    Meybe someone has io terminal and calculate remote data for me.
    Grande 2009
  16. #15
    szengen's Avatar
    Jan 2017
    rapid is right, wondering that the tango of this hole did not patch, Tango oki
