Results 1 to 4 of 4
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default opel insignia a20dtj 96 kw dpf off
    i need dpf off
    0281015774
    manual solution please
  2. The Following User Says Thank You to vasko For This Useful Post:
    sonic 1989 (22nd October, 2017)
  3. #2
    Brayn's Avatar
    Oct 2015
    Colombo
    Quote Originally Posted by vasko View Post
    i need dpf off
    0281015774
    post your ecu file ....
    you have upload wrong file
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    file ok friend
    winols find 355 maps
    mariusica_boy's Avatar
    Dpf off tested and working solution 100%.
    Disconnect connectors from differential pressure and temperature sensor.
    Pass in PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  6. The Following 3 Users Say Thank You to mariusica_boy For This Useful Post:
    Brayn (22nd October, 2017), konq100 (22nd October, 2017), pike (22nd October, 2017)
