how you know what bytes to change?
been looking for this info for long time
KVM was locked, i read motorola and change some bytes form 00 to FF to unlock KVM. But still cant add key, SKP give me error: XXX11
Abrites cant add key too. Display write: accumulator low , but it ok start car.
I need virgin KFV firmware for FK72-19H440-DA and try add with SDD.
If I Help You Please Rep + Thanks ME
You ,, unlock ,, on wrong place and wrong adress
With skp cant make nothing
Abrites make this 1000% when all is ok and good prepared
Abrites cant do it, tring many times. It read IDE of keys, but cant read ISK.
How to check if KVM unlocked?
locked KVM could show IDE of keys?
Yes
abrites make
when you start procedure and if picture where you get msg to press unlock for programing show only for second on screen then is locked.
If picture stay 5 second then is unlocked and is posiblle to match key.
IDE and ISK in advanced immo function is used for other thing.
madaxe (26th October, 2017)
Its possible adopt renewed KVM with abrites? Dont have SDD
Yes is posible
to adapt used KVM on car not need to unlock
To add new key need to unlock key
Tried today with SDD, when it prepared for download give error. What could be problem? KVM is renewed
Not enabled key learning in KVM
Same situation I'm in, anyone able to repair the P and D flash for $$$?
Try use this procedure for unlock key mode in FK72
HeXeN (6th May, 2018)
