hey friend, nyo calculates the value of 429629 km. I think vag, can not really calculate the value
i have a this car, the mileage from cluster was changed. I've opened the ECU and in the 95320 eeprom i found the real mileage, 430k km. The problem is that in the VCDS on application it shows 8 km from beginning. The car was bought with mileage changed. What can i do to change tha mileage from the vcds application. I can tell that if i change the mileage from ECU eeprom nothing is changing in the EDC16 application.
Need help, thanks
Is that a burned eeprom ?!
yes mate i changed the value to be same as dashboard. Here is the file, but why in vcds it show s 8 km? can i block it to show error ? Thanks!
Vcds bug!?
I dont know
Fvdi can do easy read and write edc16 OBD
I had exactly same problem on Golf 5 2008, on diag in ECU was showing 8 km, and couldn't connect with any programmer on EDC16 via OBD2, customer was happy with 8km in ECU so I left it like that..
i can change km too, thx for help. Haven't found any solve for this. Probably the tool that the first person modified the mileage made some changes to stuck the mileage on 8.
test..........................
rambobo (23rd October, 2017)
Hello
I have work with diagprog and enigma car from 2007 onwards edc16 reads kilomtros and value 8 k, reads direct to eeporm and real value
nikz, same error. I think that cluster eeprom is done..
