Yes, read 93c76 and post dump.
comizelu (21st October, 2017)
After logging in with the electronic code, you should see the mechanical code,
Force the module to work, turn on the emergency lights
The "customer"is a friend..very far.can't get to the car.he sent me the cim and the ignition..
Still can't understand how to decode the ignition.
Inviato dal mio HTC One utilizzando Tapatalk
Customer Friend is what's the problem?
read cim, shipping did not do, i was near the car, the car near me, .... one bolt badly screw up and it will be your fault
comizelu (22nd October, 2017)
hi
i read the 93lc76 eeprom..i done a few reads as i was not sure which one is right..
i read with vvdi prog
i need pin pls...
thank you
Definitely no pin in there mate...in either file(They're just byte swapped version of each other)
Are you trying to read this file in circuit ?
comizelu (3rd November, 2017)
Hmmm, maybe this CIM is in virgin state and that's why nno PIN code inside? Someone was working with it before? I will send PM to @TPS about this problem
Nobody touched.
My friend just took it out.
