This may sound really stupid,,, but I would like to try and redo the mileage on my 2011 berlingo 1.6 hdi..
I was considering buying an abrites fvdi clone with 18 software activated( at $150) would this work, or am I better off with something else.
I would prefer to do everything through the obd.
thank you for reading this..
regards
tfsw00
tfsw00 (23rd October, 2017)
With it being my own vehicle and it is past its sell by date, I dont mind it being difficult or damaged...can always put an ecu kit into it if things go wrong
UPDATE...
I can read the bsi with psa bsi tool,,,that leaves the dash..which my tacho pro reads but will not write,,, any advice...I have not written to the bsi yet either,,was going to change the dash,,then change the bsi,,then re-install the dash,, is this correct.
thank you
anyone with any advice?
Dash: use programmer like upa, beeprog.
And nyo ( you can find this soft here).
Bsi; smok tool or manualy with programmer and nyo.
Don't Forget erase history in Bsi and ecu.
Install bsi after dash job done.
Br
Envoyé de mon iPhone en utilisant Tapatalk
tfsw00 (24th October, 2017)
delete history? please educate..... I was planning on using the psa bsi tool with version 1.2 software it reads as a peug partner 2008-....but I know nothing about history.
thank you so far.stu
You have history dtc stored in bsi with mileage, you can't erase them with diag tool.
solution is lexia (not pps), smok tool (but don't erase all), avdi or manualy ....
regards
Thank you.
I dont suppose you have a walk through, Ihave lexia and I could do it manually if I had instructions, again any help appreciated.
kindest regards
stu
very easy car, just take off bsi and dash and open both, desolder and read eeproms
Dr. Zoidberg (26th October, 2017), sagie1zn (26th October, 2017)
