help to add key Ford mondeo 2001
Results 1 to 8 of 8
    electrones's Avatar
    Feb 2012
    Around C.V
    Default help to add key Ford mondeo 2001
    Hi friends
    I have this Ford mondeo petrol with all kes lost found in ECU ST77012 eeprom read as like 95040, so can someone help me to add key in dump please!!
    4c data
    tranponder sream
    00 00 7E 75 83 1A E0 00 00 00 00 2C 43 7E 00 00
    tiris data
    00 00 00 00 07 58 C1 AE
    THANKS IN ADVANCE
    Press "THANKS" button. just one click, CHEERS
    gokey's Avatar
    ford mondeo 2001 with 4C ?
    this car is 4D60
    try this file
    PUSH reputation and thanks If you think I helped .............................
  3. The Following User Says Thank You to gokey For This Useful Post:
    electrones (23rd October, 2017)
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friend
    Itīs my doubt too but when i put dump in EFfi is recognized like as module 83 4C where should be module 62 4D
    Iīll try and report
    Cheers
    electrones's Avatar
    Feb 2012
    Around C.V
    Sorry in delay friend is not 4C because doesnīt worked
    iīll try with 4D60
    Aug 2015
    why dont you do it by obd, much easer and even cheapest tools can do it?
    Mar 2011
    Yes mate i have the same car and same dump i load on effi it is recognize as 4C, but this car need ID 4d key I use tm100 to add key and work ok, or most easier to do via obd2 by t300, regards.
    electrones's Avatar
    Feb 2012
    Around C.V
    Thanks guys for attention
    I know but my doubt was if is 4C or 4D so i tried 4C because i dont have any 4D here
    Cheers
    Aug 2015
    your ford should be 4D id60 glass
