Results 1 to 9 of 9
    Feb 2016
    Default Opel Zafira B Dashboard clone error
    Hallo. I have the problem of cloning a cluster unit, but I can not write it with TL866 or Clone Carprog. I could only read the original content, but I can not write it to the new M35080VP.
    Details of the car: Opel Zafira B 2006
    Carprog 9.31 China clone
    TL866A fw 3.28 soft.: 6.60
    Do you have any idea?
    sida's Avatar
    May 2014
    System32
    Your tools can not write write-protected eeprom.
    Feb 2016
    Ok Thx. Solution?? I can not write a new and empty eeprom?
    sida's Avatar
    May 2014
    System32
    take a new M35080-3 or 6, not V6 or VP... and your clone should be good (if you already changed all componet on your clone to make it work). Other solution is to buy programmer which can write 35080.
    Feb 2016
    I want to load a new eeprom, but I can not. Reading with both tools succeeds.
    levisdj's Avatar
    EcuLand
    Just swap eeproms!Plus zafira b does not contain immo data in cluster!
    Feb 2016
    Okay, but I still do not understand why I can not write a blank eeprom.
    Feb 2016
    Which you recommend?
    UPA-USB
    M35080 BMW Programmer
    R270 + CAS4 Programmer
    levisdj's Avatar
    EcuLand
    Go with R270...
