HI, I must solved problem, Mercedes does not respond to the key (central locking and insertion into the ignition). Everything worked ok with the car and suddenly it happened. I thought it was a steering lock, but I connected the emulator instead and it still does not work. So I think it's a switch, but the switch is good. I corrected the soldering on one side of the pcb. But I see that under the plastic on the other side is the 9s12dt256 processor or improve the solder is enough or have to change the processor charge because it is bad? ? Everything worked ok with the car and suddenly it happened.
Yup, first to check is always key. Most common is broken coil but when remote doesn't work, it might be just PCB broken / watered. If it's NEC chip, solder it to different key and check.
teerak2uk (22nd October, 2017)
Klucz jest dobry
On Sprinter- Vito-Viano i met 2 main problems except te usual ESL or key fault:
- 1: key not accepted, but key ok, and remote work - check the reader coil it reads when you insert a key. if not, check microswitch on pcb near reader with a multimeter, usually broke.
- 2: everything seems fine, but you cannot read micro with programmer because "VCC overload" fault, than try to remove RF chip from PCB, sometimes got a short inside.
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
I am not expert Key repair but swap the nec chip in other key.
