Hello dk members,
I have an transit connect that wont start any more but after replacing the pcm it even cant read or connect to the pcm any more so i tryed to pair them again but dosn't work unfortunatly.
Then i read the ipc an pcm file to see of they are propperly match but i cant tell of its write or wrong, so is there some one how can check the file and tell me of it should work or do i have to syngronise them?
Best regards Vosje.
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
vosje1 (24th October, 2017)
Thanks a lot i will try to solve this with key progamming funtion in the car instead of the bench programming.
what year is it? I had an issue like this before with 2015 transit NA region. Pcm was not compatible. After we exact pcm id and did parameter reset function amd learn keys functions...
Also these newer system seem to take a minimum of 4 keys... 2 keys did not do it..anyways you will see it in the codes if this becomes an issue for you later on.
