Results 1 to 14 of 14
    Mar 2011
    Default immo off crafter edc16cp34 4.4
    I need immo off, I have try with immo tool 1.5, and Dont work. Somebody, please?
    Member rambobo's Avatar
    Dec 2016
    Romania
    Test and report mate
    Is that a burned eeprom ?!
    Mar 2011
    Your file is the same as the original.
    Mar 2011
    I test this file,and dont´work. Someone have solution. Thanks.
    Dec 2016
    Romania
    sorry, wrong file
    Mar 2011
    your file, is same ecuvonix. Don´t work. I test four file immo off, and nothing.
    Dec 2016
    Romania
    Something is curious here....
  8. The Following User Says Thank You to rambobo For This Useful Post:
    alcorte (23rd October, 2017)
    Mar 2011
    I think than I broke the ECU. Because I have tried all the solutions and none works. I have also put the original file in the original car, and it does not start. as if he does not have an ecu. If you remove the ECU and give the contact does the same. But if you write in the eeprom
  10. #9
    Dec 2016
    Romania
    try vcds and see if you can look in the ecu
  11. #10
    rafal's Avatar
    UK - PL
    or try to buy new eeprom end reflash whole ecu with ori files
  12. #11
    Mar 2011
    I can read/write eeprom with ktag. And it is all ok. tomorrow i try read with vcds or delphi. But I think than ecu is break.
  13. #12
    levisdj's Avatar
    EcuLand
    Have you tried reading the flash ? On ignition do you have glow plug and engine check light?
  14. #13
    Mar 2011
    Yes. I can read all. Flash, micro and eeprom. And I can write perfect. But te car dont Star, is dead, with the ori file same.
  15. #14
    dijo's Avatar
    M8, my suggestion is that you make in the first place a diagnosis to see what is going on with your car...
