Your PIN 794144! Regards!!!
quattro210 (23rd October, 2017)
Thanks mate but I had tried that one with no luck! I think it is old pin, I need new one. Sorry I did not mention that.
I'll take a look tomorrow and see if I can find another calculator and help you!!!
Thanks mate, I look foward to that. It appears you are my only hope!
Sorry, mate!!! I just looked into all possimle immo related programs and tools that I have and I can't seem to find any calculator for "new Hyundai/KIA" PIN. Every one of them gives me the old VIN to PIN calculator! Give some details about the car (Engine ECU, Immobox), maybe we can help you read the eeprom of immobox or engine ecu to retrieve the PIN. Regards!!!
Read immo dump
I will can help you'll
Read immo dump
Thanks for your troubles stefyhgs. This car is now driving me nuts! Yesterday I tried pin 066582 which I assumingly picked from the engine ecu eeprom dump (95160), T300 came up with message "incorrect pin code"! Almost immediately the immo indicator (car shape with key) came on, turned key and car started, idling beautiful, revving superb but turn off engine and everything turns ugly! Back to square one! When ignition is switched on, the immo indicator does not appear nor the engine light.I am not particularly worried about the engine light as I have met with a few Hyundais without it. Maybe I should add that this 2009 Hyundai accent was bought from an auction with no ecu, the ecu I'm trying to program is a replacement from an unknown vehicle. I had tried the code 794144 as well and it responds the same way! The T300 is the only key programmer I have and these machines are not easy to get around here! Any ideas? That goes for you too saleh ahmed! Toss over the pill for this headache! Here is the ecu eeprom 95160 dump:
Hi carcity, thanks for chirping in! Can you tell me why then the programmer tells me wrong code but then the car starts and wont start again after it is turned off?!
Hi mate. I am still struggling with the hyundai! Don't you think it is possible to go around this problem by adding keys directly to engine ecu eeprom dump?
Key 1: 1A C2 9A 11
Key 2: 0C C8 9A 11
The transponder chip is PCF7936.
Can anyone else here in DK join heads with us? Thanks in advance.
give us more detail abouth the car. engine tipe,ecu,etc... maybe can make immo off without problem on car...
Hi vlaki electric, DK, sorry I have been away deep into the bush with very little trace of civilisation!The car is fitted with petrol engine type G4ED, ecu is Kefico Hyundai part no. 39111-26BB1 (pic attached). I hope that covers all you need. Immo off will be greatly appreciated!
