Results 1 to 15 of 24
    Jan 2009
    Default Golf 5 instrument cluster swap
    I have pins from used and ori dash, enter pincode on used dash accepted but not allow channel 50 tomake adaptation to ecu. I waited almost 40 minutes but still channel 50 was ERROR on vcds
    Any tips?
    Tnx
    DUPNICA BULGARIA
    You must to have tool that read, whrite immo data (pin, mac, cs, .......). If dash is micronas after 2006y. you must to read flash and eeprom, to make working key.
    Jan 2009
    I have smok full, but ori dash was vdo and donor is visteon so can't write sec data only. Smok have visteon learn key no need of flash
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by ziko View Post
    Make imm off in ecu
    Jan 2009
    Immob active will shows onlcd...
    lush29's Avatar
    Oct 2015
    And then prog key
    yugo45's Avatar
    Use sec block helper and transfer data manually.
    And why on the Earth someone will put Visteon dash if has Micronas. Visteon dash is nothing but junk.
  8. The Following User Says Thank You to yugo45 For This Useful Post:
    amigokola (24th October, 2017)
    Jan 2009
    Yugo45 in visteon can't see pin mac.... Crypted,and when change data in sec blok save button is grey, cant save changes
  10. #9
    yugo45's Avatar
    Can you post Sec block form micronas , and full read eeprom + sec block form Visteon.
  11. #10
    Jan 2009
    Here is, I already tried to write data from ori to sec block od visteon but cant do that
  12. #11
    yugo45's Avatar
    Here is the test file.
  13. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    bearheroes (29th October, 2017), ziko (29th October, 2017)
  14. #12
    Oct 2012
    London
    Other option
    Immo off ECU, write mileage and key to cluster change coding, straight forward way if the immo is not an issue for you.
    Or get correct cluster VDO which is pretty cheap used and is easy job with immo on.
  15. #13
    Jan 2009
    Ok hope will solve like this yugo45 said. Vdo chip but this is5th dash to same costumer, all have bad LCD issue
  16. #14
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  17. #15
    yugo45's Avatar
    LCD can be replaced , they are available for Microonas dash.
