Results 1 to 2 of 2
    Jun 2016
    Default Ford Cmax sid 202 error p2585 after dpf off
    after dpf off I have error p2585. When I deleted dtc from dtc table then shows 00000 but after car run change to 00001 and check not light but on cluster lcd shows engine failure. I post a few test files but the same problem. Maybe I have to disconnect plug fuel additive sensor?
    Adam
    Romania
    Check this out and try it
  3. The Following User Says Thank You to feketezsolt For This Useful Post:
    lexuspiotrkow (7th November, 2017)
