Results 1 to 3 of 3
    Nov 2008
    Default Splitting Virmin Signal to Cable Box
    Hi All,
    I have a 200MB virmin BB installed. I also noticed there is a 3db attenuator connected to the back of my Virgin Router.
    IF I were to split the signal using the 5-1000 splitter so I can use the seccond feed in my Vusolo2 box, do I still need to use the attenuator or would it be okay to just connect both 2 output into the Cable box and the Virmin Hub. Picture of the attenuator below
    Any suggestion would be greatly appreciated.
    Thanks in advance.
    digicon's Avatar
    Before you do anything make a note of the Signal levels on the VM superhub router page, then split the cable and attach feed to Router again and have a look at the levels if they are near enough the same forget fitting the attenuator
  3. The Following User Says Thank You to digicon For This Useful Post:
    saayinla (30th October, 2017)
    Nov 2008
    Many thanks, will try this out and update this thread.
