Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    number7hd's Avatar
    Dec 2013
    Default PEUGEOT CITROEN RNEG - doesn't work - how to reanimate ?
    RNEG from 2010y. maps on SD.
    Display shows only "System check in progress. Please wait and do not switch off the engine for 25 min."
    Engine can run even all day and system won't start.
    In firmware R50 we can find folder EMEGGENCY_KIT with files to load it up, even with instruction in PDF.
    But there is no instruction how to connect to mainboard. RNEG mainboard has plug on edge.
    I'm sure we can do it with RS232 but I need pinout to mainboard plug...
    Does anyone can share solution?
    If my solution helped You - do not forget to THANKS !!!
    number7hd's Avatar
    Dec 2013
    I found it .... if someone need it - here You go...
  3. The Following 21 Users Say Thank You to number7hd For This Useful Post:
    adjee (15th February, 2019), axl (13th November, 2018), Col19 (22nd December, 2021), Epap (17th February, 2019), freeman2014 (12th September, 2019), g485 (28th May, 2018), glk96000 (8th November, 2019), gsmflasch (25th July, 2022), ilkovelichkov (13th May, 2021), juned2 (12th September, 2019), laki23 (19th July, 2022), mexanico1971 (20th July, 2023), michael 28 (7th January, 2018), norishor (16th February, 2021), PetShakal (4th December, 2022), ruemzaigc (28th February, 2024), sikib (10th November, 2018), sozeri (10th February, 2018), swissdriver (30th May, 2020), Weld hammadi (19th October, 2020), xdamdamx (2nd January, 2019)
    Mar 2010
    SAN RAFAEL MZA.
    hello friend has more information with this procedure. What soft do you use and so on? or who has that kind of information?
    number7hd's Avatar
    Dec 2013
    On firmware CD is folder "Emergency kit" with TUTORIAL in PDF. All You need is:
    1. USB RS232
    2. TUTORIAL which is on CD
    3. TerraTerm terminal which is in Internet
  6. The Following 23 Users Say Thank You to number7hd For This Useful Post:
    armpower (20th February, 2018), audiopoint (14th February, 2018), BusCan (24th September, 2020), Col19 (22nd December, 2021), eric paris (31st July, 2020), Faraday (3rd August, 2019), g485 (6th June, 2018), girolamodisidisi (26th October, 2022), glk96000 (8th November, 2019), gsmflasch (25th July, 2022), hrmotorsport (10th April, 2018), ilen (10th August, 2018), laki23 (19th July, 2022), Latuachiave (19th September, 2023), matik185 (12th March, 2019), mexanico1971 (22nd March, 2023), mido007 (26th June, 2019), norishor (16th February, 2021), npero (26th January, 2024), PetShakal (4th December, 2022), RadioChiP (19th August, 2018), sikib (10th November, 2018)
  7. #5
    May 2017
    España
    once restored is needed code with lexia?
    and, whaat cd is needed, original comes with car? if dont have this cd, how to do?
  8. #6
    number7hd's Avatar
    Dec 2013
    All You need is firmware, which You can download from NET.
  9. #7
    Newbie drechu11's Avatar
    Mar 2016
    Poland
    Martech Programmer that repair this unit
  10. #8
    uk
    hi have you got the firmwere please i have same problem thanks
  11. #9
    jjrp255630's Avatar
    Jun 2009
    porto portugal
    hi, who have sucesseful fix the rneg?
    im trying, but i dont know what im doing wrong, i can do comunication with radio, apear rneg script, but i can ZR, is always says erasing....
  12. #10
    Feb 2019
    Default RNEG Reboot bug
    Hello
    Many people as me in France have a specific trouble with the RNEG 1 (harman Beker) unit and some others have also this trouble with the RNEG2 (Magneti Marelli): these units are working well but reboot at regular intervals (every 30 mn for mine)
    I can understand that the trouble comes from a eeprom being corrupted (why?... no idea as I am just a normal driver)
    Repair consists probably in re writing the eeprom after clearing it (I am not sure) but costs a lot (600 € through Citroen network and that is unacceptable for just flashing an eeprom)
    Does anybody know wether using the Reanimate Your RNEG procedure found on the update firmware files would solve the reboot trouble?
    Thanks for your suggestions or now how
  13. #11
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by Epap View Post
    Hello
    Just update firmware, you will see if helped..
  14. #12
    Feb 2019
    Quote Originally Posted by matik185 View Post
    Thanks for the idea
    I thought as you that the update could help but unfortunately after updating the firmware the undesired periodic reboot was still there.
    I would like to try to investigate through the serial communication but currently i am not able to understand this kind of programmation ..
    Will see
  15. #13
    Dec 2009
    Quote Originally Posted by number7hd View Post
    i have martech box 3 , i connect with rneg but i have this problem
    when i clic on emergency start i have this message:
    Connecting...
    Error. Connection failed.
    why the rneg does not accept the update ?
    can you help me how to resolv this problem
  16. #14
    Dec 2009
    problem solved
  17. The Following User Says Thank You to talel66 For This Useful Post:
    her (4th November, 2022)
  18. #15
    Apr 2019
    Hello, I have a problem following the update of the firmware R50.3 which did not go through. I performed the manipulation to reanimate my rneg, but I can’t send the file "install_rnegd.ifs" by ZModem in Tera Term. In Tera Term I have this in loop :
    IPL: RNEG (6426.C1/0), 300 MHz
    [ver.10325A, built 2010-08-13 10:35:16 1931854]
    CS0: NOR
    boot img #0 from NOR [FPGA missing]... --- loaded 4907 KB in 649 ms [3552 => 7743 K/sec]
    *** jumping to c0200bc0 ...
    Startup: PL_qnx_startup-atlas2_07241A, built 2007/06/11_14-47-38_UTC
    Board: 00006426.000000c1
    RAM: 124 MB
    FLASH: 64 MB @0x10000000
    cpu_clock=300000000, dsp_clock=200000000, sys_clck=100000000, io_clock=100000000
    Dcache: 512x32 WB
    Icache: 512x32
    arm926 rev 4 300MHz
    System page at phys:c0017000 user:fc404000 kern:fc404000
    Starting next program at vfd0203a8
    Unknown type 255
    Shutdown[0,0] S/C/F=11/1/11 C/D=fd005fd0/fd05c060 state(c0)= now lock
    [0]PID-TID=1-4? P/T FL=00019001/05020000 "proc/boot/procnto-instr"
    armle context[fd06694c]:
    0000: 00000011 0000000a 00000064 00010000 fd0905dc fd54ccf8 0000ffff 00000000
    0020: fd0014c8 00000010 fd059488 fd552f24 fc423000 fd552eb4 fd024160 fd001834
    0040: 6000001f
    instruction[fd001834]:
    03 20 f5 e7 01 30 d5 e5 03 64 92 e1 c0 ff ff 1a 01 00 a0 e3 c0 76 00 eb 00 70
    stack[fd552eb4]:
    0000: 00000000 6f72702f 6f622f63 7000746f 6e636f72 692d6f74 7274736e 00000000
    0020: 00000007 fd05bff8 00000000 00000000 00000000 00000000 00000000 fd049f00
    0040: 00000000 00000000 00000000 00000000 fd05a0d0 fd54e050 fd553008 00000000
    0060: 00000000 fd552f50 fd552f28 fd04b6d4 fd0014f8 fd553008 fd54e050 fd553008
    getdipclose
    Can someone help me? Thank you in advance, everyone.
