Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Sep 2009
    Default help to decode VW RCD500 MP3
    i need help to decode this unit,i dont know where is code stored?in eep or in MCU,???
    more details:
    RCD500 MP3
    3C0 035 XXX B
    model: CQ:EV1572G
    VWZ5Z7G XXXX XXXX
    thanks in advence
    Jun 2009
    Quote Originally Posted by mafioso3 View Post
    more details:
    RCD500 MP3
    3C0 035 XXX B
    model: CQ:EV1572G
    VWZ5Z7G XXXX XXXX
    thanks in advence
    in 93C76 smd
    post dump and i will give you the code
    Sep 2009
    her is the dump
  4. The Following User Says Thank You to mafioso3 For This Useful Post:
    Jun 2009
    this is a MATSUSHITA and not a Blaupunkt, i did think i have the algo for this but I'm afraid i do not have it
  6. #5
    Sep 2009
    i think code is in MCU M30833
    but need programmer for this type of IC
  7. #6
    V.I.P. Member milanoffracing's Avatar
    Jul 2009
    Bulgaria,Sofia
    RCD500 is maded by Blaupunkt and code is stored in eeprom 95640
  8. #7
    Sep 2009
    Quote Originally Posted by milanoffracing View Post
    there is not 95640 inside RCD500 MP3 is maded by VW and not blaupunkt
  9. #8
    Jul 2009
    Bulgaria,Sofia
    Sorry, my mistake.
  10. #9
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Model: VWRCD 500 MP3
    Code: 0000-1999
    Number: CQ-EV1572G 3C0 035 195B
    Manufacturer: MATSUSHITA
    Processor: M30833FJ
    EEprom: 93C76 smd
    Code located in:???????
    I don't find any information about code on this model
    PS: Please test dump from attach. Possible code off (not tested)
    PPS: I just read that the code is stored in processor. Sry mate
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  11. #10
    Sep 2009
    Quote Originally Posted by lupu_sandu View Post
    Code: 0000-1999
    Processor: M30833FJ
    EEprom: 93C76 smd
    the code is in M30833FJ,EEprom: 93C76 just for counter
    The M32C/83 RENISAS Group (M32C/83, M32C/83T) microcomputer is a single-chip control unit that utilizes highperformance
    silicon gate CMOS technology with the M32C/80 Series CPU core.
    so we need programmer for it
  12. #11
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Read here mate, and maybe you can read procesor:
    M16C-Flasher
  13. The Following User Says Thank You to lupu_sandu For This Useful Post:
    soukehal (19th April, 2016)
  14. #12
    Sep 2009
    M16C-Flasher
    this software need interface schematic
  15. #13
    Use simple interface MAX232 need only RX, TX, Reset MC16 Flasher work ok
  16. #14
    DK Veteran magdex's Avatar
    POLAND
    Maybe Some Pinout of MCU or Pic how to Connect TX,RX and Reset
    I have tha same radio to decode !
    Regards !
  17. #15
    Sep 2009
    please upload good and tested shematic interface
    i think M30833FJ need more than RX TX,here is Target interface to M16C62/M16C80/M32C (M30624/M30625/M30800)
    VCCS Positive supply voltage of target
    BUSY Target CPU Busy signal output.
    SCLK Target CPU Serial clock (input)
    EPM EPM signal of target CPU
    GND Common signal ground
    RESET RESET signal of target system
    CNVss Target CPU CNVss signal
    TxD Target CPU Serial data output
