any idea!!!!!!!!!!waiting for schematic interface
See here-VW RCD500 http://www.carhelp.info/forums/60/th...ghlight=rcd500
Try your modifiet dump.Maybe will work without code.
[I]Automotive Electronics Solutions
Mercedes-Benz Reverse Development Engineer ...
Mercedes CFF 2010-2017 CFF all models all modules
Vediamo help flashing over teamviewer ...
JLR SDD online + offline ...last official ...
this is the method for read m32c interface schematic. connect RK7 to +12v .
-vdd with 100 ohom to cnvss
-rst with push to gnd
-pin 9 max232 to rx uc
- pin 8 max232 to tx uc
-gnd max232 to gnd uc
and the M16c flasher select type of uc in setting and uncheck erase all ,with com1 baudrat 9600
press connect and push reset button
the uc will connect and press read button and press ok
that s all.
ccode (20th February, 2018), laurentiudania (19th April, 2016), shooting (10th January, 2016), sonices (18th February, 2016)
Many thanks for sharing,helped a lot
Nobody?
If there is someone who can advise me how to see the code after reading the M30833FJ
HI RADYO KODU Yardımı?
RCD 500 MP3 3C0 035 195B MODEL: CQ-EV1572G EEprom: 93C76 HW: 012 SW: 0018 BARKOD NO: * 014VWZ5Z7G1109853L *
immokill (3rd December, 2019), juisro (18th February, 2018), masterskay62 (18th February, 2018), rch11 (6th March, 2018), stormb (15th August, 2019)
Hello! What is " connect RK7 to +12v" ? Thank you!
Thank for answer! Power +12v across resistor 4,7K Ohm to Vdd,may be ...
+ 12c across Resistor 4, 4K to Vdd+ 12c across Resistor 4, 4K to Vdd
I have a solution to the problem!
1. Connect 9pin from max232 to Rx MCU
2.Connect 10 pin from max232 to Tx MCU
3. Gnd to Gnd
4.Connect DB9 connector to RS port
5. Start program "connect"
6. Connect power +12v to Radio (without resistor 4,7K Ohm)
7.Read MCU- I am happy!
