i need help to decode this unit,i dont know where is code stored?in eep or in MCU,???
more details:
RCD500 MP3
3C0 035 XXX B
model: CQ:EV1572G
VWZ5Z7G XXXX XXXX
thanks in advence
more details:
RCD500 MP3
3C0 035 XXX B
model: CQ:EV1572G
VWZ5Z7G XXXX XXXX
thanks in advence
her is the dump
this is a MATSUSHITA and not a Blaupunkt, i did think i have the algo for this but I'm afraid i do not have it
i think code is in MCU M30833
but need programmer for this type of IC
Model: VWRCD 500 MP3
Code: 0000-1999
Number: CQ-EV1572G 3C0 035 195B
Manufacturer: MATSUSHITA
Processor: M30833FJ
EEprom: 93C76 smd
Code located in:???????
I don't find any information about code on this model
PS: Please test dump from attach. Possible code off (not tested)
PPS: I just read that the code is stored in processor. Sry mate
Read here mate, and maybe you can read procesor:
M16C-Flasher
soukehal (19th April, 2016)
Use simple interface MAX232 need only RX, TX, Reset MC16 Flasher work ok
Maybe Some Pinout of MCU or Pic how to Connect TX,RX and Reset
I have tha same radio to decode !
Regards !
please upload good and tested shematic interface
i think M30833FJ need more than RX TX,here is Target interface to M16C62/M16C80/M32C (M30624/M30625/M30800)
VCCS Positive supply voltage of target
BUSY Target CPU Busy signal output.
SCLK Target CPU Serial clock (input)
EPM EPM signal of target CPU
GND Common signal ground
RESET RESET signal of target system
CNVss Target CPU CNVss signal
TxD Target CPU Serial data output
