Perhaps u mean power steering and UCH.
Lot of tools can virgine power steering (renolink, renault tool, AVDI...) ... and it's autocoded after.
Just check if it is not a standard problem with powersteering DF002 error.
Hello lads
Got a 2006 clio 3 here with immobiler issue
I think I need to renew sync between uch and esp
What tools can I buy to do this job? Don't want to spend a lot of money for a 1 time job
Cheers lads
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
norman1967 (10th November, 2017)
Hello. Yes esp my bad typo
I have posted the fault I get see image.
Car will not start dash led flashing.
I have genuine avdi but not the Renault licence
I don't want to buy an expensive licence for only 1 car
Read eeprom and write virgin is cheapest way, but more work removing column.
norman1967 (11th November, 2017)
Thank you. I would have done that but I did not know it was an option. I have just bought renolink software.
Hopefully it will do it over obd
