PP2000
https://mega.nz/#!TAx0GBRA!CvhP4KbL95_ePi5fXlQ6-PRrXw1QokoJr2EEs4eNCds
https://mega.nz/#!uNQSgTya!kQ0547AETU4PqcrW1mbnVDTpyWRsJuzGd_6uLnqm6Do
Button: Thanks and star:Add to this user"s reputation... good habit
Hello, I need valid access to Peugeot to re-encode my injectors. The injector codes were deleted after chiptuning. Manual writing is not possible because the injectors are aligned with the control unit. My Peugeot 206 HDI 110 FAP only runs in emergency mode. Help
I would buy the access, but it's just credit card and I do not have a credit card.
PP2000
kotnascher (12th November, 2017)
No connection !!!
The codes you have on the injectors, look for it - read on the internet.
kotnascher (13th November, 2017)
What is the IMA Code?
Spent some time with the software and found in diagbox under manual config all the info I needed. Input the first 8 digits of the nine digit number etc
http://mhhauto.com/Thread-1-6-HDI-EDC16C34-Injector-coding-not-accepted
Invalid Invitation Code, Your invitation code has either expired or is incorrect. Please try again or request a new invitation code to complete your registration.
Do you know how to use pp2000? because what you are doing is completely wrong. Do not you work from an authorized Peugeot workshop? for the one image you have uploaded, where to login with D number. And that login can only be obtained if you work at Peugeot or have a purchase license (which is expensive). Unfortunately, you need to understand how to use the software
with best regards
