Results 1 to 2 of 2
    Mar 2017
    Default Recommended Diagbox version for fw 4.3.2
    I have a lexia3 chinatown clone which in PSA Interface Checker shows:
    Version of the current application:
    APPLI_XS_Fuji_P106138A V4.3.2 @ACTIA 03.01.14
    Reference Serial:
    921815 C
    Never used it, but a friend asked me if he could bring his citroen xsara 2001 to try it because he wants to buy one.
    I have diagbox v7.57 installed in my laptop. The cd I have contains some updates to higher versions, i think up to 7.82 is the highest (filename is "diagbox update (8.18) v7.76 vers v7.82 english version.exe"). Also have all the updates needed to go from 7.57 to that one.
    What's the recommended diagbox version I should use (without having to upgrade firmware)?
    ElectroRadar's Avatar
    Mar 2018
    Mexico
    that is already a matter of trial and error, since most interfaces are designed to work with updatable software, you can update it to the latest version, if it does not work, install it again until the version that the interface works for you and / or what I have seen that the programs fucnionan without problems in winodows xp in other windows they give problems and we think that it is problem of the interface or of the programs greetings and I hope to already have been able to solve your doubt
