Results 16 to 30 of 34
Thread: No sound.
  1. #16
    digicon's Avatar
    ABM is not pre-installed but is easily installed from the Plugin menu, if i recall iPab is actually built around the OpenATV image so you could wait and see if iPab gets updated at some point
  2. #17
    Mar 2012
    Belfast - Northern Ireland
    Yeah, I will hold out a bit for an update in iPab as I like how it works.
    It's an annoying issue but not the end of the world.
    Sent from my SM-G950F using Tapatalk
  3. The Following User Says Thank You to grahampaull For This Useful Post:
    accies (14th November, 2017)
  4. #18
    Member accies's Avatar
    Nov 2008
    Took your advice and it fixed all of my problems with sound . Thanks for your advice digicon
  5. #19
    May 2008
    Im from Manchester in the United Kingdom
    Hi There
    Hope you don't mind me jumping on this thread I have a H3.2TC, I have re-flashed with openatv-6.1-zgemmah32tc-20171117, I have installed oscam_atv 1.2 11353 and configured my line and it is working nice I have installed abm 2.9 from plug-ins and entered my region code then tried to update config files and it just comes back with this "config file from virmin uk does not need updating" Im trying to fix the NAR issue but cant seem to resolve it.
    Any help with this would be appreciated.
    Cheers
    Pete
  6. #20
    digicon's Avatar
    Quote Originally Posted by fermec View Post
    Hi There
    Cheers
    Pete
    Do an Online update as the fix was not implemented properly until the 18/11, Also you dont need to update the config file on a recently flashed image the fix is already built into the image.
    PPS. can i also remind members we do not discuss any issues to do with Softcams or so called 'Lines' forum rules
  7. #21
    May 2008
    Thanks for the update I will try and do an update when I get home from work later.
    Sorry if I broke the rules your comments have been noted.
    Pete
  8. #22
    May 2008
    Al working now thanks digicon
  9. The Following User Says Thank You to fermec For This Useful Post:
    digicon (21st November, 2017)
  10. #23
    take it if i have a dm800 hd running a newenigma 2 image will not have an audio fix?
  11. #24
    maca's Avatar
    Feb 2009
    liverpool
    Yes it will mate openatv 6.1 has it
  12. #25
    Quote Originally Posted by maca View Post
    are you aware of an upto date image for the DM800 HD?
  13. #26
    maca's Avatar
    Feb 2009
    liverpool
  14. #27
    maca's Avatar
    Feb 2009
    liverpool
    Plus read through some of the threads regarding this issue you'll find all the answers there
  15. The Following User Says Thank You to maca For This Useful Post:
    gio65_00 (27th November, 2017)
  16. #28
    The image is for an SE model. Will it work with just the DM800 HD? Mine is not a SE model
  17. #29
    maca's Avatar
    Feb 2009
    liverpool
    Yes mate ............
  18. #30
    Cheers mate, will give it a try
